[postgis-devel] Release notes for 1.3.4
Kevin Neufeld
kneufeld at refractions.net
Mon Nov 24 18:30:25 PST 2008
OK... Fire away.
Paul Ramsey wrote:
> OK, it sounds like we are getting down to brass tacks.
> I've put this content into NEWS.
> Kevin, there's a 1.3.4 file already in the downloads directory, from
> an old autorun, that'll have to be moved out of the way.
> Time to release, methinks...
> p.
> On Thu, Nov 20, 2008 at 7:18 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
>> Obe, Regina wrote:
>>> My only suggestion.
>>> These I don't consider bug fixes and I think should be moved to Features
>>> or we create a new section called Enhancements. To me bug fixes are
>>> correcting things that don't produce the right outputs rather than
>>> making turtles faster or more understandable.
>>> Enhancements
>>> - Improve PiP code by removing substantial memory leaks and adding
>>> multi-polygon support (Paul Ramsey)
>>> - Improve GiST consistent performance (Paul Ramsey)
>>> - General documentation improvements (Regina Obe, Kevin Neufield)
>>> - GBT#20: Improved algorithm for ST_DWithin (also proposed ST_DFullyWithin
>>> ?) (Paul Ramsey) (I don't think we ever did the
>>> ST_DFullyWithin)
>> Yeah, I think renaming the first section from Features to Enhancements and
>> including the above in Enhancements would work fine (I'm not too concerned
>> either way). Since Paul is the release manager, I guess we should let him
>> determine the final text and perform the final commit to the 1.3
>> documentation release notes.
>> ATB,
>> Mark.
>> Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
