[postgis-devel] Issue 72 in postgis: ST_Estimated_Extent sometimes returns null if table exists but not in current schema
codesite-noreply at google.com
Tue Nov 25 02:26:27 PST 2008
Updates:
Status: Fixed
Labels: Milestone-1.4
Comment #8 on issue 72 by mark.cav... at siriusit.co.uk: ST_Estimated_Extent
http://code.google.com/p/postgis/issues/detail?id=72
Added quick fix to 1.3 branch and trunk, although too late for 1.3.4
release (and
1.3.x should be kept stable regardless). Bumping milestone to 1.4.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
