[postgis-devel] README patch and \set ON_ERROR_STOP
strk
strk at keybit.net
Wed Nov 26 01:52:46 PST 2008
Is there any counter-argument about adding an '/set ON_ERROR_STOP'
directive on top of lwpostgis.sql ?
It is much nicer to see what goes wrong on spatially-enabling
a database. Supposedly available starting with version 8.1, but
does it any harm for previous versions ?
Beside, following is a patch for README.postgis
Index: README.postgis
--- README.postgis (revision 3336)
+++ README.postgis (working copy)
@@ -147,7 +147,7 @@
So, as postgres run:
createlang plpgsql yourdatabase
- psql -f lwpostgis.sql -d your_database
+ psql -f lwgeom/lwpostgis.sql -d <your_database>
Your database should now be spatially enabled.
--strk;
() ASCII Ribbon Campaign
/\ Keep it simple!
