[postgis-devel] README patch and \set ON_ERROR_STOP
strk
strk at keybit.net
Wed Nov 26 04:22:21 PST 2008
On Wed, Nov 26, 2008 at 11:46:21AM +0000, Mark Cave-Ayland wrote:
> The policy for SVN trunk is that we only support PostgreSQL 8.1+, so
> that's fine with me. The main issue I have with this is that adding the
> above means that the file will only work with psql, and that doesn't
> seem a particularly good idea (I know that EDB use their own customised
> loader, for example).
> Perhaps the nicer solution would be to change the instructions so that
> ON_ERROR_STOP is fed in as an option to psql?
Yeah, -v ON_ERROR_STOP=1, worth documenting in the README.postgis then.
--strk;
