[postgis-devel] regress_bdpoly failed
Cooper, Alexander P R
aprc at bas.ac.uk
Wed Nov 26 09:36:24 PST 2008
3D geometry is part of GML 3, the joint OGC/ISO TC211 standard for GML. Also included is topological structuring; temporal topology didn't make the cut. I don't think there is a separate specification equivalent to the OGC simple feature model.
I'm on ISO TC211, so if you need to know about standards progress, I may be able to help.
Paul Cooper
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of strk
Sent: 26 November 2008 17:30
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] regress_bdpoly failed
On Wed, Nov 26, 2008 at 02:47:04PM +0000, Mark Cave-Ayland wrote:
> Please feel free to suggest any solution as to how GEOS should create
> OGC-compliant geometries in 3 dimensions :)
Uhm. Should refresh my memory.
IIRC there was no OGC doc about 3d when I worked on adding
that support in GEOS.
Does GEOS trunk still do it ?
--strk;
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
