[postgis-devel] Issue 75 in postgis: Enhancement to PIP short circuit
codesite-noreply at google.com
Wed Nov 26 12:32:59 PST 2008
Status: New
Owner: ke... at refractions.net
Labels: Type-Enhancement Priority-Low
New issue 75 by ke... at refractions.net: Enhancement to PIP short circuit
http://code.google.com/p/postgis/issues/detail?id=75
The PIP short circuit in predicates like ST_Intersects and ST_Contains is
currently defined for POINT - [MULTI]POLYGON pairs. This algorithm could
be expanded to include MULTIPOINTs, esp. for one-member-multipoint cases
and optionally in a few-member-multipoint cases (if performance testing
warrants it).
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
