[postgis-devel] Issue 77 in postgis: make check - is there anyway for us to delete postgis_reg db when load fails
codesite-noreply at google.com
Thu Nov 27 10:03:14 PST 2008
Status: New
Owner: robe.... at cityofboston.gov
Labels: Type-Enhancement
New issue 77 by robe.... at cityofboston.gov: make check - is there anyway for
http://code.google.com/p/postgis/issues/detail?id=77
What steps will reproduce the problem?
1. make check
2. check fails during loading of postgis
3. you run make check again after compilation
4. it fails again
5. Oh yah have to do dropdb postgis_reg before you can run make check again
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
