[postgis-devel] Issue 77 in postgis: make check - is there anyway for us to delete postgis_reg db when load fails
codesite-noreply at google.com
Fri Nov 28 01:55:16 PST 2008
Comment #1 on issue 77 by mark.cav... at siriusit.co.uk: make check - is there
http://code.google.com/p/postgis/issues/detail?id=77
I'd be +1 for making the regression script drop the database by default
(and have
keeping it as a separate option), as this has caught me out so many times...
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
