[postgis-devel] Issue 33 in postgis: AddGeometryColumns function does not check if SRID is valid
codesite-noreply at google.com codesite-noreply at google.com
Thu Oct 2 10:39:20 PDT 2008
Issue 33: AddGeometryColumns function does not check if SRID is valid
http://code.google.com/p/postgis/issues/detail?id=33
Comment #2 by pwramsey3:
Committed invalid srid check to 1.3 branch and trunk at r3053.
Issue attribute updates:
	Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
