[postgis-devel] Prepared Geometry API
David Fuhry
dfuhry at acm.org
Mon Oct 6 10:53:40 PDT 2008
ctid will work for that, but I believe it would have to be passed into
the function as a separate argument from the geometry, so API ugliness
remains.
-Dave
Chris Hodgson wrote:
> The problem with both memcmp and hashing is that the case that we our
> trying to speed up, where the geometry is the same as the previous one,
> invokes the worst case run time. memcmp WILL have to compare every byte,
> and your hashes WILL be equal, so you WILL have to do a memcmp anyway to
> check that it's not due to a collision. In the cases that we are really
> trying to speed-up, the number of successful comparisons will be
> hundreds to millions of times more than the unsuccessful comparisons.
> The cases that get the biggest speedup from the cached prepared geometry
> are the big geometries, which are also the ones that take the longest to
> memcmp.
> Perhaps there any way to ask postgresql if we are still working with the
> same tuple? The query engine must know, at some level, which row is on
> the side of the join or condition that isn't changing, and which one is
> being looped through... getting at that info is the only alternative I
> can see to the Id approach that doesn't have most of it's performance
> gain destroyed by memcmp. Or can we hack in something like
> generate_series to automatically give us a "tuple id"?
> Chris
> Mark Cave-Ayland wrote:
>> It's not so much an index, just a unique identifier for each geometry
>> that can be used to determine whether it is already in the prepared
>> cache. At the moment, synthetic keys are used with an extended API so
>> as to provide a direct key into the cache. I'm wondering if we could
>> use something else such as a CRC32 (assuming the PostgreSQL hash
>> implementation handles collisions using memcmp() internally).
>> *thinks*... maybe GEOS should generate a CRC32 hash key as part of the
>> creation of the prepared geometry? Assuming we could access this using
>> a the GEOS CAPI, it would just be a case of handling the few
>> collisions using memcmp()...
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
