[postgis-devel] Dropped DM (Time) dimension with intersections
Huntington, Margaret (US SSA)
margaret.huntington at baesystems.com
Tue Oct 7 08:46:49 PDT 2008
Hello,
Currently I'm using PostGIS 1.3.3. From past discussions and from
testing, both the st_intersection st_extend methods return 2D results
with 4D input geometries. As a temporary work-around, I had hoped
st_intersection might work with 3DM geometries. (Plan was to
interpolate the altitude value within the function call if PostGIS could
calculate the time dimension). I found time components are also
dropped by st_intersection with 3DM geometries. I abandoned usage of 4D
bounding boxes since these too effectively degrade 4D geometries down to
2D geometries (altitude and time are zeroed out).
polyGeometry geometry;
bbGeometry geometry;
intersectionGeometry geometry;
coorddims smallint;
-- both polygon and linestring have an expected zmflag value
of 1
polyGeometry := 'SRID=4326;POLYGONM((0 0 0, 0 10 4, 10 10 4,
10 0 0, 0 0 0))'::geometry;
bbGeometry := 'SRID=4326;LINESTRINGM(0 0 1.5, 10 10
2)'::geometry;
intersectionGeometry := st_intersection(polyGeometry,
bbGeometry);
-- st_intersection method drops the time dimension; zmflag
value of 0
coorddims := st_zmflag(intersectionGeometry);
If I were to download the subversion snapshot, the current 1.4 version,
might st_intersection work with either 3DM or 4D geometries? Are
bounding boxed or st_extend improved for either 3DM or 4D geometries? I
had incorporated polygons only as a possible work-around to the bounding
box and st_extend 2D limitations.
Margie
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081007/8b8758ac/attachment.html>
