[postgis-devel] Dropped DM (Time) dimension with intersections
Chris Hodgson
chodgson at refractions.net
Tue Oct 7 11:10:48 PDT 2008
I think the answer is, nobody really knows, but it seemed to make as
much sense as possible given the operation being requested. If it
doesn't work for your use case then feel free to make a solid argument
for why we should give a different result and provide a robust method to
calculate it :-)
Chris
Obe, Regina wrote:
> Which begs the question - what exactly does this tell me?
> SELECT
> ST_AsEWKT(ST_ConvexHull(ST_Collect(ST_GeomFromEWKT('LINESTRING(1 2 3,3
> 4 5, 3 6 7)'), ST_MakePoint(0, 2, 0))));
> Result
> "POLYGON((0 2 0,3 6 7,3 4 5,1 2 3,0 2 0))"
