[postgis-devel] Prepared Geometry API
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Oct 7 13:29:34 PDT 2008
Obe, Regina wrote:
> Paul,
> Something is bugging me about your choice of example. Not that it is
> important, but your a and b tables are the same constant so I would
> expect a planner to realize that and make a and b point to the same
> thing. I'm not sure how that muddies your analysis. Also your constant
> gets cast as a geometry only when it gets into ST_Contains and you are
> doing a UNION instead of a UNION ALL.
> What does the revised query give you
> SELECT a.val as a, b.val as b, st_contains(a.val, b.val,0)
> FROM
> (SELECT 'POINT(0 0)'::geometry as val UNION ALL SELECT 'POINT(1
> 1)'::geometry as val) a,
> (SELECT 'POINT(3 4)'::geometry as val UNION ALL SELECT 'POINT(1
> 1)'::geometry as val) b;
> Thanks,
> Regina
The UNION ALL seems to work for me. Using the attached patch against SVN
trunk and EXPLAIN, it is possible to see that it is the Materialize node
which causes the Datum pointers to change. Also it's worth noting that
st_contains() invokes the bounding box filter first which is a little
confusing when looking at this - things were a lot clearer to me using
the following queries:
SELECT a.val as a, b.val as b, _st_containsprepared(a.val, b.val,0)
FROM
(SELECT 'POINT(0 0)'::geometry as val UNION SELECT 'POINT(1
(SELECT 'POINT(3 4)'::geometry as val UNION SELECT 'POINT(1
FROM
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
Type: text/x-diff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081007/1e9f6a46/attachment.patch>
