[postgis-devel] ST_Extent3D
Obe, Regina
robe.dnd at cityofboston.gov
Wed Oct 8 13:02:06 PDT 2008
What do we use ST_Extent3D for and should it be documented? Seems to do
something for 3D geometries, but I'm not quite sure since I was
pictureing an Extent of a 3d to be a cube not a box in 3D space.
Is that why its not documented?
SELECT ST_Extent3d(the_geom)
FROM (SELECT ST_MakePoint(x,y,z) As the_geom
FROM generate_series(1,3) x
CROSS JOIN generate_series(2,4) y
CROSS JOIN generate_series(1,2) z) as foo
Gives - BOX3D(1 2 1,3 4 2)
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
