[postgis-devel] 1.4 SVN Compile problems
Kevin Neufeld kneufeld at refractions.net
Fri Oct 10 09:03:00 PDT 2008
Ah, that would make sense.  The tarball snapshot is of the last stable
build.
-- Kevin
Obe, Regina wrote:
> Kevin,
> I just realized I must be pulling from the SVN nightly snapshot since my
> lwgeom compiles fine and has the old name lwgeom_geos_c.c.
> Its just the loader I seem to be having trouble with.
> Now if only I could make heads or tails of what Mark is saying I could
> try that :). Guess I better go read.
> Paul,
> Whatever happened to your ground rules - Whatever you do don't break the
> build. :)
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
> Kevin Neufeld
> Sent: Friday, October 10, 2008 11:17 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] 1.4 SVN Compile problems
> It could simply be that trunk is currently in an unstable build state.
> (The autobuild is currently in a broken state as of three commits ago -
> revision 3086).  It errors out compiling lwgeom_geos.o
> http://postgis.refractions.net:8082/
> Cheers,
> Kevin
> Mark Cave-Ayland wrote:
>> Obe, Regina wrote:
>>> This is probably my ineptness at compiling, but I thought I would try
> to
>>> experiment with 1.4 and got errors when its trying to compile the
>>> loader. Errors below.  If I go into lwgeom etc. other directories and
>>> compile those separately, those seem to compile okay so seems to be
> just
>>> the loader that is giving me problems.
>>> What changed between 1.3.4SVN and 1.4SVN for the loader.  I didn't
> have
>>> problems compiling 1.3.4SVN.
>>> The others just seem to be warnings (which I don't remember getting
>>> before) except for this part
>>> lkrb5 -lz -lreadline -lcrypt -ldl -lm  -o shp2pgsql
> /usr/lib/gcc/i586-suse-linux/4.2.1/../../../../i586-suse-linux/bin/ld:
>>> cannot find -lkrb5
>>> collect2: ld returned 1 exit status
>>> This is on OpenSUSE 10.3 against a PostgreSQL 8.2.6 install
>>> Thanks,
>>> Regina
>> Hmmmm looks as if the extra library dependencies are being added by
> PGXS
>> for the PROGRAM target - I have no idea why it feels the need to do
> this
>> though? The quick fix is to add the krb5 development headers which
>> should be in a package named something similar to krb5-devel or
>> libkrb5-dev.
>> ATB,
>> Mark.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
