[postgis-devel] 1.3.4
Obe, Regina
robe.dnd at cityofboston.gov
Fri Oct 10 12:02:47 PDT 2008
But if you are using geos 3.0.0 it is not going to try and use prepared geometry at all correct?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Fri 10/10/2008 2:22 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] 1.3.4
OK, I've made the prepared geometry work underneath the existing API,
so the key-based API has been removed.
Make sure you have the latest GEOS before trying these things, as
anything prior to the current revision still has leaks.
Paul
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081010/874e79c1/attachment.html>
