[postgis-devel] intersects also seems to have problem with CircularStrings
Ken Southerland
southerland at samsix.com
Fri Oct 10 12:22:54 PDT 2008
Again, postgres 8.2 and postgis 1.3.1.
select st_intersects( geom, buffer(setsrid('BOX(601361.4700644684
355218.2141958948, 601668.4150596277 355416.58465439035)'::box2d,
32015), 5.0)) from features where geom && setsrid('BOX(601361.4700644684
355218.2141958948, 601668.4150596277 355416.58465439035)'::box2d, 32015);
...gives...
ERROR: Exception in LWGEOM2GEOS: curved geometry not supported.
... if the geom column in features has a curved geometry in it, but
confusingly the following query works...
select st_intersects( 'BOX(0 0, 3 3)'::box2d,
GeomFromText('CIRCULARSTRING(1 1, 2 2, 1.5 1.5)'));
... so i'm not sure if it's the intersects method or some other deeper
method that get's called in the former. Is there a way to show more of
a stack trace with the error message?
Ken
------s----a----m----s----i----x------
Ken Southerland
Senior Consultant
Sam Six, Inc.
503-358-6542
http://www.samsix.com
