[postgis-devel] Issue 57 in postgis: Re-work prepared geometry to use a custom memory context
codesite-noreply at google.com
Fri Oct 10 16:09:32 PDT 2008
Issue 57: Re-work prepared geometry to use a custom memory context
http://code.google.com/p/postgis/issues/detail?id=57
Comment #1 by pwramsey3:
Alternate approach using a child MemoryContext of the fmgr context to
trigger a
callback and clean-up, following example in transform cache.
Issue attribute updates:
Status: WontFix
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
