[postgis-devel] Issue 19 in postgis: Prepared* Functions appear to be leaking memory
codesite-noreply at google.com
Fri Oct 10 16:17:33 PDT 2008
Issue 19: Prepared* Functions appear to be leaking memory
http://code.google.com/p/postgis/issues/detail?id=19
Comment #1 by pwramsey3:
GEOS leaks and PostGIS leaks removed. Fixed in trunk and 1.3 as of r3090
Issue attribute updates:
Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
