[postgis-devel] 1.3.4SVN Testers Needed
Dane Springmeyer blake at hailmail.net
Mon Oct 13 13:21:51 PDT 2008
Paul,
Just tried building GEOS from the provided svn download on Mac 10.5.5
and I get this error during make:
	then mv -f ".deps/Unload.Tpo" ".deps/Unload.Plo"; else rm -f ".deps/
Unload.Tpo"; exit 1; fi
  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/
headers/geos -I../../source/headers -g -O2 -DGEOS_INLINE -Wall -ansi -
pedantic -Wno-long-long -MT Unload.lo -MD -MP -MF .deps/Unload.Tpo -c
Unload.cpp  -fno-common -DPIC -o .libs/Unload.o
Unload.cpp -o Unload.o >/dev/null 2>&1
if /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -
I. -I. -I../../source/headers -I../../source/headers/geos -I../../
source/headers     -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-
long-long -MT CLocalizer.lo -MD -MP -MF ".deps/CLocalizer.Tpo" -c -o
CLocalizer.lo CLocalizer.cpp; \
	then mv -f ".deps/CLocalizer.Tpo" ".deps/CLocalizer.Plo"; else rm -f
".deps/CLocalizer.Tpo"; exit 1; fi
pedantic -Wno-long-long -MT CLocalizer.lo -MD -MP -MF .deps/
CLocalizer.Tpo -c CLocalizer.cpp  -fno-common -DPIC -o .libs/
CLocalizer.o
CLocalizer.cpp:1:32: error: geos/io/CLocalizer.h: No such file or
directory
CLocalizer.cpp:11: error: 'CLocalizer' has not been declared
CLocalizer.cpp:11: error: ISO C++ forbids declaration of 'CLocalizer'
with no type
CLocalizer.cpp: In function 'int geos::io::CLocalizer()':
CLocalizer.cpp:16: error: 'saved_locale' was not declared in this scope
CLocalizer.cpp: At global scope:
CLocalizer.cpp:21: error: expected constructor, destructor, or type
conversion before '::' token
CLocalizer.cpp:19: warning: control reaches end of non-void function
make[2]: *** [CLocalizer.lo] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
I see it must be related to http://trac.osgeo.org/geos/ticket/201
Let me know if I'm missing something.
Dane
On Oct 13, 2008, at 11:57 AM, Paul Ramsey wrote:
> 1.3.4 is very close to release, but we can release it faster, with
> less intestinal distress, if we get some solid pre-release testing
> from folks. You can download the current SVN version directly from the
> downloads page, no SVN client required:
> http://postgis.refractions.net/download/postgis-1.3.4SVN.tar.gz
> If you want to also try the latest preparedgeometry enhancements,
> you'll need to upgrade your GEOS version to the SVN trunk before
> compiling and installing1.3.4SVN,
> http://download.osgeo.org/geos/geos-svn.tar.bz2
> Even if you don't, you should see some performance increases in 1.3.4,
> particularly in point-and-polygon predicate tests, and large joins
> using point-ant-polygon predicates.
> Let us know how it goes. We are particularly  interested in any
> compilation difficulties or regression failures on less common unix
> variants (Solaris on Sparc, AIX on Power, etc)
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
