[postgis-devel] Issue 59 in postgis: pg_detoast_datum_slice handle points
codesite-noreply at google.com codesite-noreply at google.com
Tue Oct 14 09:27:57 PDT 2008
Issue 59: pg_detoast_datum_slice handle points
http://code.google.com/p/postgis/issues/detail?id=59
New issue report by pwramsey3:
when a slice is pulled, make it large enough that the bbox for points can
be calculated from the raw data, and enhance the bbox pullers to do just
that in the special case.
Issue attributes:
	Status: Accepted
	Owner: pwramsey3
	Labels: Type-Enhancement Priority-Medium
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
