[postgis-devel] 1.3.4
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 14 12:02:59 PDT 2008
I've put in a special case in the GiST change for 7.2, since the
sliced detoaster only arrived in 7.3. If testing turns out OK, I'd
like to release 1.3.4 semi-soon. I'd like to hear from people doing
work with points, to see if the double-detoast is a problem. I can
put in Dave's point-handling idea if it is.
P.
On Tue, Oct 14, 2008 at 1:33 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Devrim GÜNDÜZ wrote:
>> On Mon, 2008-10-13 at 10:36 +0100, Mark Cave-Ayland wrote:
>>> i) PostgreSQL 7.2 testing
>>> Yes, I know it's really old but it was agreed to keep older version
>>> support until 1.4 :( So we should make sure that everything compiles and
>>> passes regression.
>> ? Why do we have to support a release which was killed by upstream years
>> ago? Are there any 7.2 users around?
>> We should also drop 7.3 support, and get ready to drop support for 7.4
>> as of next March or so.
> Yeah, I think it's related to some legacy systems still in use by some
> people. But fortunately for 1.4 we've already agreed we can move to
> something a lot more modern, so this will be the last branch that goes back
> this far.
> In terms of dropping support for other versions, the main issues moving
> forward are the changes in the GiST API, and IIRC the next large set of
> changes are related to 8.0...
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
