[postgis-devel] Issue 60 in postgis: Tarball of 1.3.3 has object files and .svn directories; impossible to build without clean on MacPro
codesite-noreply at google.com
Tue Oct 14 16:23:54 PDT 2008
Issue 60: Tarball of 1.3.3 has object files and .svn directories;
http://code.google.com/p/postgis/issues/detail?id=60
Comment #2 by ke... at refractions.net:
Fixed. (For this tagged release as well as the branch and trunk tarballs).
A ./configure and make is required to build the documentation that's
included in the
tarball. This script was recently integrated into a new autobuild process,
which is
now cleaning up via a make clean before packaging up the tarball.
Note: The PostGIS has not been under attack and the postgis-1.3.3.tar.gz
does not
have malicious content. This file was updated to include a generated PDF
of the
documentation when the autobuild process went online a month ago.
Perhaps we should include MD5 checksums on the download website?
Issue attribute updates:
Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
