[postgis-devel] Issue 60 in postgis: Tarball of 1.3.3 has object files and .svn directories; impossible to build without clean on MacPro
codesite-noreply at google.com
Tue Oct 14 21:06:02 PDT 2008
Issue 60: Tarball of 1.3.3 has object files and .svn directories;
http://code.google.com/p/postgis/issues/detail?id=60
Comment #3 by xander:
Awesome. Thanks for fixing.
As to whether to include MD5s, it's probably a good idea, though obviously
your call.
I was using MacPorts, which puts a SHA or MD5 in every port file to check
against the
source tarball. Since the tarball changed with the new autobuild process,
MacPorts
threw an error when it tried to pull down the new tarball.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
