[postgis-devel] PostGIS 1.4 SVN geometry parser hints
Kevin Neufeld
kneufeld at refractions.net
Wed Oct 15 08:53:46 PDT 2008
Nice work Mark. I like it. That should definitely help with assisting
newcomers with WKT syntax.
Is it possible to put it on other ERROR messages, like "ERROR: GEOS
intersects() threw an error!"? It could suggest they snap to a grid to
avoid topology errors or perhaps simply a "You found a bug" and provide
a url to the bug tracker.
Nice :)
Kevin
Mark Cave-Ayland wrote:
> Hi everyone,
> Just so that it doesn't come as too much of a surprise, I remembered
> that with the new parser API in place within SVN trunk, we can now
> return extra information from the parse phase, including the position of
> any errors. Since we are now using a minimum of PostgreSQL 8.1, it means
> we can use the HINT functionality to tag this additional information to
> the original ERROR message.
> So as of SVN trunk, you now see an extract of the input geometry up to
> the point where the parse failed (marked with an arrow), followed by the
> absolute position of the error like this:
> postgis=# select 'test1', astext(geomfromtext('LINESTRINGA(0 0)'));
> ERROR: parse error - invalid geometry
> HINT: "LINESTRING" <-- parse error at position 10 within geometry
> CONTEXT: SQL function "geomfromtext" statement 1
> postgis=# select 'test2', astext(geomfromtext('LINESTRING(0 0)'));
> ERROR: geometry requires more points
> HINT: "LINESTRING(0 0)" <-- parse error at position 15 within geometry
> postgis=# select 'test3', astext(geosnoop('POLYGON((0 0, 0 1, 1 1, 2 1,
> 3 1, 4 1, 5 1, 6 1, 7 1, 8 1))'));
> ERROR: geometry contains non-closed rings
> HINT: "... 1 1, 2 1, 3 1, 4 1, 5 1, 6 1, 7 1, 8 1)" <-- parse error at
> position 58 within geometry
> Nice :) I'm not 100% set upon the HINT output format (it was the
> clearest I could come up with to fit on one line after a bit of playing
> around), so if anyone can think of anything better, please shout.
> ATB,
> Mark.
