[postgis-devel] PostGIS 1.4 SVN geometry parser hints
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Oct 16 01:39:36 PDT 2008
Mark Cave-Ayland wrote:
>> postgis2=# select 'MULTIPOYGON(((0 0, 0 0, 0 0,0 0),(0 0, 0 0, 0 0,0
>> 0),(0 0, 0 0, 0 0,0 0),(0 0, 0 0, 0 0,0 0),(0 0, 0 0, 0 0,0
>> 0)))'::geometry;
>> ERROR: parse error - invalid geometry
>> HINT: "" <-- parse error at position 0 within geometry
> I think this is because MULTIPOLYGON is a token in the grammar, and so
> since the first token doesn't match the current position is still zero
> when the error occurs. I'm not sure if there is a way of getting the
> current character offset from within flex at this point...
Okay. Since the first item in a WKT input is always a string
representation of the geometry type such as POINT etc, I've added a
different message to SVN trunk to catch the special case where the error
location is zero. Your test case now looks like this:
postgis=# select 'MULTIPOYGON(((0 0, 0 0, 0 0,0 0),(0 0, 0 0, 0 0,0
0)))'::geometry;
HINT: You must specify a valid OGC WKT geometry type such as POINT,
LINESTRING or POLYGON
...which I think is a lot more helpful.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
