[postgis-devel] Issue 61 in postgis: lack of support for South African projections
codesite-noreply at google.com codesite-noreply at google.com
Sat Oct 18 00:40:51 PDT 2008
Issue 61: lack of support for South African projections
http://code.google.com/p/postgis/issues/detail?id=61
Comment #1 by mark.cav... at siriusit.co.uk:
Hi Gavin,
Are you able to provide an SQL file that can be run to confirm each of
these cases in
turn? And what do you mean by invalid - are you saying that PROJ.4 can't
parse the
proj4text field?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
