[postgis-devel] 1, dot, 3 dot 4!
Obe, Regina
robe.dnd at cityofboston.gov
Sun Oct 19 16:06:33 PDT 2008
P,
that got me further but no go. Seems to be same issue in an unpatched file
then mv -f ".deps/ByteOrderValues.Tpo" ".deps/ByteOrderValues.Plo"; else rm -f ".deps/ByteOrderValues.Tpo"; exit 1; fi
g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/geos -I../../source/headers -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT ByteOrderValues.lo -MD -MP -MF .deps/ByteOrderValues.Tpo -c ByteOrderValues.cpp -fPIC -DPIC -o .libs/ByteOrderValues.o
ByteOrderValues.cpp: In static member function static double geos::io::ByteOrderValues::getDouble(const unsigned char*, int):
ByteOrderValues.cpp:139: error: memcpy was not declared in this scope
ByteOrderValues.cpp: In static member function static void geos::io::ByteOrderValues::putDouble(double, unsigned char*, int):
ByteOrderValues.cpp:147: error: memcpy was not declared in this scope
make[2]: *** [ByteOrderValues.lo] Error 1
make[2]: Leaving directory `/projects/geos-3.0.2/source/io'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/projects/geos-3.0.2/source'
make: *** [all-recursive] Error 1
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Sun 10/19/2008 5:14 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1, dot, 3 dot 4!
Yes, this has already been fixed on trunk, here's a patch against 3.0,
let me know if it helps.
P.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081019/e6528f06/attachment.html>
