[postgis-devel] 1, dot, 3 dot 4!
Kevin Neufeld
kneufeld at refractions.net
Mon Oct 20 08:39:47 PDT 2008
I fixed the tarball and the date on the website.
I wonder if the autobuild for the 1.3 development branch played some
roll in this, since for a while, the Version.config in the 1.3
development branch and 1.3.4rc1 tag had the same version number.
Perhaps the autobuild overwrote the tagged tarball of the same name,
postgis.1.3.4rc1.tar.gz.
I temporarily changed the 1.3 autobuild branch to no longer use the
Version.config for params, so this shouldn't happen in the future until
a better solution can be found.
-- Kevin
Obe, Regina wrote:
> Paul,
> Hmm - I just downloaded the
> http://postgis.refractions.net/download/postgis-1.3.4rc1.tar.gz
> and it has an inner folder
> postgis-1.3.4svn
> I suspect this may cause some people some confusion?
> Why is the date listed as Oct 12th? I thought you released that just
> recently in the past day or so?
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
