[postgis-devel] 1.3.4rc1
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 21 05:24:39 PDT 2008
Thanks Greg, I've added your dragonfly lines so they'll be there in
final. Feel free to test against 1.3svn if you like.
P.
On Mon, Oct 20, 2008 at 7:35 AM, Greg Troxel <gdt at ir.bbn.com> wrote:
> The PostGIS team is pleased to provide release version 1.3.4rc1 for
> your testing delectation.
> You may download it from:
> http://postgis.refractions.net/download
> I dropped that version into pkgsrc (but am not committing it), and built
> against geos 3.0.2, proj 4.6.0, and pgql 8.1.14 on NetBSD/i386
> 4.0_STABLE.
> The patch at the end of this mail is in pkgsrc to add dragonfly support
> and it would be nice to apply it upstream, although I realize it is the
> 11th hour.
> The rc1 tarball unpacked into postgis-1.3.4svn instead of the expected
> postgis-1.3.4rc1.
> I tried to run make check before installing postgis, and that failed
> immediately, but README.postgis implies it should work. After
> installing, make check succeeded. I do not understand how pre-install
> make check could work, so perhaps this is just a documentation buglet.
> patch:
> $NetBSD: patch-aa,v 1.3 2006/12/06 17:43:27 joerg Exp $
> --- lwgeom/Makefile.shlib.orig 2006-12-06 17:36:49.000000000 +0000
> +++ lwgeom/Makefile.shlib
> @@ -140,6 +140,10 @@ ifeq ($(PORTNAME), freebsd)
> endif
> endif
> +ifeq ($(PORTNAME), dragonfly)
> + LINK.shared = $(COMPILER) -shared -Wl,-x,-soname,$(soname)
> +endif
> ifeq ($(PORTNAME), netbsd)
> ifdef ELF_SYSTEM
> make test log with postgis not installed:
> gdt 105 /usr/pkgsrc/geography/postgresql81-postgis > make test
> => Bootstrap dependency digest>=20010302: found digest-20080510
> ===> Testing for postgresql81-postgis-1.3.4rc1
> Using GNU make found at /n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/.tools/bin/gmake
> gmake[1]: Entering directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn'
> /n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/.tools/bin/gmake -C regress test
> gmake[2]: Entering directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn/regress'
> Creating spatial db postgis_reg
> ERROR: function postgis_lib_version() does not exist
> HINT: No function matches the given name and argument types. You may need to add explicit type casts.
> Something went wrong (no postgis installed in postgis_reg).
> For details, check /tmp/pgis_reg_15161/regress_log
> gmake[2]: *** [test] Error 1
> gmake[2]: Leaving directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn/regress'
> gmake[1]: *** [check] Error 2
> gmake[1]: Leaving directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn'
> gmake: *** [check] Error 2
> *** Error code 2
> Stop.
> make: stopped in /n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis
> *** Error code 1
> Stop.
> make: stopped in /usr/pkgsrc/geography/postgresql81-postgis
> /tmp/pgis_reg_15161/regress_log:
> CREATE DATABASE
> BEGIN
> psql:lwpostgis.sql:44: NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> psql:lwpostgis.sql:44: ERROR: could not access file "/usr/pkg/lib/liblwgeom": No such file or directory
> psql:lwpostgis.sql:50: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:56: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:62: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:70: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:88: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:94: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:100: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:106: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:113: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:131: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:137: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:143: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:149: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:156: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:162: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:170: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:176: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:182: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:188: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:204: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:215: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:221: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:228: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:234: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:241: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:247: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:254: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:260: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:267: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:273: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:280: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:286: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:292: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:298: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:304: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:310: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:317: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:323: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:330: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:336: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:344: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:351: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:358: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:364: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:382: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:388: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:394: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:400: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:407: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:413: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:419: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:425: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:431: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:437: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:443: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:449: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:455: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:461: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:467: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:473: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:479: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:497: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:503: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:509: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:515: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:523: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:542: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:548: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:554: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:560: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:567: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:575: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:581: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:587: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:593: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:599: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:605: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:611: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:617: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:623: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:629: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:635: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:641: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:647: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:653: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:659: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:665: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:671: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:677: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:690: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:696: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:702: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:708: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:714: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:720: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:726: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:732: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:738: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:744: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:750: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:756: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:766: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:772: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:778: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:784: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:789: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:800: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:816: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:826: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:838: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:850: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:856: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:862: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:868: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:874: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:880: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:886: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:892: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:898: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:904: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:910: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:916: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:922: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:928: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:934: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:940: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:946: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:952: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:958: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:964: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:970: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:976: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:982: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:988: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:994: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1002: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1008: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1014: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1020: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1026: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1032: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1038: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1044: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1050: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1056: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1062: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1068: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1081: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1086: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1091: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1096: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1101: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1106: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1111: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1142: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1151: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1164: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1170: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1176: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1182: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1188: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1194: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1200: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1206: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1216: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1222: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1228: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1234: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1240: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1246: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1252: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1258: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1264: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1270: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1276: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1282: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1288: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1294: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1300: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1310: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1316: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1322: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1328: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1334: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1340: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1346: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1352: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1364: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1370: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1376: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1382: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1387: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1393: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1401: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1407: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1413: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1419: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1425: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1431: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1439: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1445: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1451: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1457: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1463: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1469: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1477: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1484: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1490: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1496: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1502: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1508: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1514: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1520: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1527: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1533: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1540: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1546: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1552: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1558: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1564: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1570: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1580: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1586: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1592: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1598: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1605: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1611: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1617: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1623: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1629: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1635: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1641: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1647: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1653: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1659: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1665: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1671: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1677: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1683: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1690: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1697: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1703: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1709: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1716: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1723: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1729: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1735: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1743: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1752: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1758: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1764: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1770: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1776: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1782: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1788: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1794: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1800: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1806: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1812: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1818: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1824: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1830: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1836: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1842: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1848: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1854: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1860: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1866: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1872: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1878: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1884: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1890: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1896: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1902: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1908: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1914: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1920: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1926: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1932: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1938: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1944: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1950: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1956: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1962: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1968: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1978: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1984: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1990: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:1996: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2002: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2008: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2014: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2020: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2026: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2032: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2038: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2044: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2050: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2056: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2062: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2068: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2074: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2080: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2086: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2092: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2098: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2104: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2110: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2116: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2122: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2128: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2136: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2144: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2150: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2156: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2162: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2168: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2174: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2180: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2186: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2192: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2198: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2204: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2212: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2220: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2223: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2229: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2235: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2241: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2247: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2260: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2266: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2273: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2280: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2286: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2292: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2299: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2306: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2319: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2325: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2334: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2340: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2357: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2368: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2378: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2384: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2393: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2399: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2407: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2412: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2420: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2425: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2445: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2462: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2482: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2498: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2509: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2527: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2543: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2652: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2746: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2923: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2941: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:2959: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3031: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3053: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3075: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3120: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3132: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3145: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3233: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3249: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3265: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3279: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3293: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3332: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3345: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3352: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3357: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3363: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3372: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3376: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3386: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3390: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3395: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3399: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3403: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3407: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3411: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3415: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3467: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3477: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3483: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3489: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3495: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3501: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3507: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3513: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3519: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3525: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3531: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3537: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3543: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3549: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3555: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3562: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3568: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3574: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3580: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3586: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3592: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3598: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3604: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3610: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3616: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3622: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3628: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3634: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3640: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3646: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3649: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3650: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3651: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3652: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3653: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3654: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3655: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3656: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3657: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3658: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3659: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3660: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3661: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3672: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3678: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3685: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3691: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3698: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3704: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3711: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3717: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3724: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3730: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3736: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3742: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3752: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3758: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3764: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3770: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3776: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3782: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3788: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3794: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3800: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3806: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3816: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3822: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3828: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3834: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3840: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3846: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3852: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3858: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3865: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3871: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3877: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3883: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3889: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3895: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3901: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3907: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3913: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3919: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3925: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3932: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3939: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3945: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3951: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3959: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3967: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3973: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3979: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3985: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3991: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:3997: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4003: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4009: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4015: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4022: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4028: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4034: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4040: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4046: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4053: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4058: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4064: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4071: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4077: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4083: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4090: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4096: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4102: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4109: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4115: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4121: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4127: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4134: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4141: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4147: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4154: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4160: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4167: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4173: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4179: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4185: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4191: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4197: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4203: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4209: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4215: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4221: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4227: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4233: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4239: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4249: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4255: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4261: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4267: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4273: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4279: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4288: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4295: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4301: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4308: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4314: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4321: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4328: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4337: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4344: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4350: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4357: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4364: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4370: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4377: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4384: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4394: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4400: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4406: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4412: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4418: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4424: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4430: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4441: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4447: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4453: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4459: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4465: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4471: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4477: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4483: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4489: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4495: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4501: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4507: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4513: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4519: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4525: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4531: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4537: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4564: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4570: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4576: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4582: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4588: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4594: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4600: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4606: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4612: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4618: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4624: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4630: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4636: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4642: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4648: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4654: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4660: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4666: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4672: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4678: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4684: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4690: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4696: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4702: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4708: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4714: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4720: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4726: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4732: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4738: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4744: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4750: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4756: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4762: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4767: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4772: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4777: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4782: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4792: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4802: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4812: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4823: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4833: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4843: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4853: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4863: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4869: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4875: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4885: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4895: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4905: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4915: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4921: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4927: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4933: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4939: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4950: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4961: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4971: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4981: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4987: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4993: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:4999: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5005: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5015: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5025: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5035: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5045: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5051: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5057: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5063: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5069: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5075: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5085: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5095: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5105: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5115: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5121: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5127: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5133: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5139: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5150: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5161: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5172: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5183: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5189: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5195: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5201: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5207: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5217: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5227: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5237: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5247: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5257: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5267: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5277: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5287: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5297: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5307: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5317: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5327: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5337: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5347: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5357: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5367: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5377: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5387: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5397: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5407: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5417: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5427: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5437: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5447: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5457: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5467: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5477: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5487: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5497: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5507: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5517: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5527: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5537: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5547: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5557: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5567: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5577: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5587: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5597: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5607: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5617: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5627: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5637: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5647: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5658: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5669: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5680: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5691: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5734: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5763: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5799: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5823: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5867: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5918: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5925: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5932: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5939: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:5972: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6005: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6012: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6017: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6022: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6081: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6099: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6144: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6203: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6223: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6280: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6303: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6317: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6331: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6345: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6351: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6357: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6395: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6444: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6467: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6473: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6497: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6508: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6513: ERROR: current transaction is aborted, commands ignored until end of transaction block
> psql:lwpostgis.sql:6518: ERROR: current transaction is aborted, commands ignored until end of transaction block
> ROLLBACK
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
