[postgis-devel] isvalid(geom), but st_ashexewkb(geom, 'NDR')::geometry fails
Kevin Neufeld
kneufeld at refractions.net
Fri Oct 24 08:51:44 PDT 2008
I was going to say that it looks like a bug in the WKB parser, but then
I noticed that this is fixed in newer PostGIS versions.
In my 1.1.6 version, I can produce the same thing - it's clearly not
symmetric.
postgis=# select
astext('0106000020C90E00000100000001030000000100000000000000'::geometry);
astext
MULTIPOLYGON(( EMPTY))
(1 row)
postgis=# select astext('MULTIPOLYGON(( EMPTY))');
ERROR: parse error - invalid geometry
-- Kevin
David Fuhry wrote:
> Regina,
> Yeah, I agree that the WKT is not valid. The real question is, is
> the WKB valid? If not, isvalid() should return false. If so, the
> parser should parse it without error.
> ST_GeomFromText('MULTIPOLYGON EMPTY') returns a different geometry
> from mine. Adding the srid makes it a little closer, but not the same.
> Both of these are correctly identified as st_isempty(), although mine
> is not.
> db=> select st_geomfromtext('MULTIPOLYGON EMPTY');
> st_geomfromtext
> 010700000000000000
> (1 row)
> db=> select setsrid(st_geomfromtext('MULTIPOLYGON EMPTY'), 3785);
> setsrid
> 0107000020C90E000000000000
> (1 row)
> Thanks,
> Dave
> Obe, Regina wrote:
>> David,
>> I don't think that is valid WKT syntax for an EMPTY multipolygon. If I
>> try to stuff that in via ST_GeomFromText it returns invalid geometry.
>> Not sure how you got that in there.
>> It should be
>> SELECT ST_GeomFromText('MULTIPOLYGON EMPTY');
>> On 1.3.3 and 1.3.4SVN - when I do this - I get the below which is also
>> kind of odd. I would have expected it to maintain the empty polygon.
>> SELECT ST_IsValid(the_geom), ST_AsText(the_geom),
>> ST_IsEmpty(the_geom), ST_AsEWKT(the_geom) FROM (SELECT
>> ST_GeomFromText('MULTIPOLYGON EMPTY') As the_geom) As foo ;
>> st_isvalid | st_astext | st_isempty |
>> st_asewkt
>> t | GEOMETRYCOLLECTION EMPTY | t |
>> (1 row)
>> Hope that helps,
>> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net on behalf of David
>> Fuhry
>> Sent: Thu 10/23/2008 11:28 PM
>> To: PostGIS Development Discussion
>> Subject: [postgis-devel] isvalid(geom), but
>> st_ashexewkb(geom,'NDR')::geometry fails
>> I have an empty multipolygon which isvalid(), but which the parser
>> throws "ERROR: geometry requires more points" on. Is this a bug in
>> isvalid(), or in the parser? Interestingly, st_isempty() returns false.
>> db=> select geom from tt;
>> geom
>> (1 row)
>> db=> select st_astext(geom) from tt;
>> st_astext
>> (1 row)
>> db=> select isvalid(geom) from tt;
>> isvalid
>> t
>> (1 row)
>> db=> select st_ashexewkb(geom,'NDR')::geometry from tt;
>> db=> select st_isempty(geom) from tt;
>> st_isempty
>> f
>> (1 row)
>> db=> select version(), postgis_version();
>> version
>> | postgis_version
>> PostgreSQL 8.3.1 on i486-pc-linux-gnu, compiled by GCC cc (GCC) 4.2.3
>> (Debian 4.2.3-4) | 1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
>> (1 row)
>> Thanks,
>> Dave
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> * The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the sender
>> and delete the material from any computer. *
>> * Help make the earth a greener place. If at all possible resist
>> printing this email and join us in saving paper. *
