[postgis-devel] Re: [postgis-users] 1.3.4rc2 Released
Greg Troxel gdt at ir.bbn.com
Fri Oct 24 13:28:11 PDT 2008
  We continue to inch closer to a 1.3.4 release. Please compile and test
  1.3.4rc2, available from
  http://postgis.refractions.net/download/postgis-1.3.4rc2.tar.gz
On NetBSD 4 i386 with geos 3.0.2 and pg 81, pkgsrc locally updated to
refer to this instead of the (committed) 1.3.3.  Dragonfly patch
removed, and packing list updated showing difference in what's installed
From 1.3.3, but not a problem in any way, just noting:
Index: PLIST
RCS file: /cvsroot/pkgsrc/geography/postgresql81-postgis/PLIST,v
retrieving revision 1.9
diff -u -p -r1.9 PLIST
--- PLIST       17 Oct 2008 23:42:19 -0000      1.9
+++ PLIST       24 Oct 2008 20:25:59 -0000
@@ -6,15 +6,7 @@ lib/liblwgeom.so.1
 lib/liblwgeom.so.1.3
 man/man1/pgsql2shp.1
 man/man1/shp2pgsql.1
-share/doc/html/postgis/apa.html
-share/doc/html/postgis/ch01.html
-share/doc/html/postgis/ch02.html
-share/doc/html/postgis/ch03.html
-share/doc/html/postgis/ch04.html
-share/doc/html/postgis/ch05.html
-share/doc/html/postgis/ch06.html
-share/doc/html/postgis/ch07.html
-share/doc/html/postgis/index.html
+share/doc/html/postgis/postgis.html
 share/doc/html/postgis/style.css
 share/doc/postgis/README.postgis
 share/doc/postgis/ZMSgeoms.txt
Builds fine and passes make check, so looks fine.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081024/849c99fe/attachment.sig>
