[postgis-devel] SVN trunk parser modifications stage 2
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Oct 27 05:13:52 PDT 2008
Kevin Neufeld wrote:
> Having a new variable in the custom_variable_classes list sounds like a
> good idea.
> So, does this mean that we will be able to set the parser level for the
> duration of the transaction? Or can this only be set for the duration of
> the session?
> SET LOCAL postgis.default_parser_check_level TO 0;
> -- or equivalently,
> SELECT set_config('postgis.default_parser_check_level', '0', true);
> Cheers,
> Kevin
I now have some experimental code that uses just the plain GUC
variables, and well... it's horrendously messy :(
The main issue is that due to PostgreSQL's delayed function loading, the
new GUC isn't available until the first PostGIS function is called which
causes some interesting synchronisation issues where either i) SHOW
postgis.parser_check_level causes an ERROR if custom_variable_classes
isn't set, and ii) changing the value using ALTER... SET cannot update
the parser flags until the first time the parser is called. So using
this, I was finding in testing that different combinations of commands
in different orders would succeed or fail accordingly which is not good.
The problem with the stored procedures, of course, is that we can't
easily reset to the default settings which makes interfacing with
connection pooling particularly painful :(
On the basis of this, I'm now thinking that we need to take a different
approach to get something that is going to work. I'm now thinking that
the best way to approach this would be to tackle this from the
input/output function perspective, perhaps having a separate function
like ST_GeomFromTextWithStrict() or similar that will allow the correct
strictness setting to be supplied. Then ST_GeomFromText() will remain
OGC-compliant, while we give the user to chance to override this if
required, much in the same way that ST_AsEWKT() works.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
