[postgis-devel] Issue 62 in postgis: PgSQL 8.4 Support in PostGIS 1.3
codesite-noreply at google.com
Mon Oct 27 10:56:28 PDT 2008
Issue 62: PgSQL 8.4 Support in PostGIS 1.3
http://code.google.com/p/postgis/issues/detail?id=62
New issue report by pwramsey3:
Title says it all. Mark says:
"Yeah, I'm in 2 minds about it at the moment although that's mainly because
the 1.3 branch build
system is a complete pain ;) If you want to have a go at this yourself
then it looks like you need to
tweak http://svn.refractions.net/postgis/branches/1.3/Makefile.config.in to
filter out the devel
suffix (I think I used sed in trunk to do this?), plus backport the 8.4
GiST fix from here:
http://postgis.refractions.net/pipermail/postgis-commits/2008-August/000413.html."
Issue attributes:
Status: Accepted
Owner: pwramsey3
Labels: Type-Enhancement Priority-Medium
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
