[postgis-devel] 1.3.4rc1
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Oct 28 10:49:07 PDT 2008
Courtin Olivier wrote:
> Well the point (to my opinion) is to be able to send to client only the
> amount of data really
> needed.
> Generalisation could be a way (ST_SImplify, ST_SnapToGrid), and decimal
> precision
> an another (and sometime both of them)
> So i keep thinking that's the most usefull way to handle that for
> PostGIS users is a decimal
> precision approach (%*.f) rather than a significant digits (%*.g)
True, but then this throws up the issue in the regression tests whereby
different platforms have different precisions in terms of decimal
places. The only thing we know that can control this is significant
figures - for example, even if the user specifies a precision of 15 then
we know for a fact that the number doesn't contain this information, and
the problem gets worse the larger the numbers.
The problem gets worse in that the native sprintf() function only
handles decimal places rather than significant figures in %f mode, so it
looks like we may need to engineer ourselves a new output function. On
the plus side, we can permanently solve the issue with regression tests
on all platforms due to floating point drift.
So this only leaves the question of would changing the meaning of the
function in this way cause you great problems? Given that most data
should be within a similar area, I think specifying a slightly different
fixed precision should give you a similar result as you have now.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
