[postgis-devel] [PostGIS] #180: History table example implementation
trac at osgeo.org
Tue Oct 7 18:16:11 PDT 2008
Reporter: pramsey | Owner: pimpaa
Type: enhancement | Status: assigned
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by robe):
Just my two cents and should probably shut up on this. I woudl create a
differnt schema for history tables, kind of like how PostgreSQL has a
different schema for toast tables so as not to confuse people and
otherwise clutter the schema.
So if the user schema a table is in is say public, call the history schema
history_public or soem such thing.
I guess thinking out loud for my scenario -- I have say 150 tables in one
of my schemas -- most I would like to use this history feature. But I
won't, cause I don't want to wade thru 300 tables :)
history is a nice thing when you need to look at it interrorogate it, but
otherwise you want it to be abstracted away from your common workflow and
not to confuse unsuspecting users.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/180#comment:10>
