[postgis-devel] [PostGIS] #219: Run 'make check' without needing 'make install' first
trac at osgeo.org
Wed Oct 8 08:55:03 PDT 2008
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by strk):
With this patch applied, running 'make check' from top-level dir uses
the wrong $(PWD). We need an absolute path most likely, or making sure
runtest* cd into regress before continuing.
This is a very good improvement for testing!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/219#comment:1>
