[postgis-devel] [PostGIS] #219: Run 'make check' without needing 'make install' first
trac at osgeo.org
Wed Oct 8 09:21:29 PDT 2008
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment (by pramsey):
It's good to indicate the SVN revision you committed to, so that issue
readers can easily click to the final changeset. In this case, r4284 on
trunk.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/219#comment:3>
