[postgis-devel] point_in_multipolygon implementation
Obe, Regina
robe.dnd at cityofboston.gov
Thu Sep 11 12:56:17 PDT 2008
Andre,
Interesting - never noticed that was commented out and I was looking at
that section. That could answer another timing puzzle I had. I'm not
sure why it is commented out.
Can you tell me how much of a speed difference you get by using
ST_DWithin vs. decomposing your geometry to a single polygon and using
ST_Contains
Something like
SELECT pt.gid as pointid, poly as polyid
FROM
poly INNER JOIN points pt
ON ST_DWithin(poly.the_geom, p.the_geom, 0.001)
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mose
Andre
Sent: Thursday, September 11, 2008 3:35 PM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] point_in_multipolygon implementation
In trunk, lwgeom_functions_analytic.c:1397 and thereabouts is a
commented out point_in_multipolygon function.
We have noticed a performance gain by convincing contains
(lwgeom_geos_c:1388) to use the point_in_polygon shortcut, but our
application uses a lot of multipolygons. Rather than switch the
client code to decompose multipolygons (most of them are a single
polygon anyway) it would be nice to just implement this other
shortcut.
Does anyone know why it's not functional? Or have any recommendations
on how to fix it up? I cannot find any discussion on the lists.
Thanks,
Mose
>From lwgeom_functions_analytic.c:
* return 0 iff point is outside every polygon
/* Not yet functional.
int point_in_multipolygon(LWMPOLY *mpolygon, LWPOINT *point)
int i;
#ifdef PGIS_DEBUG_CALLS
lwnotice("point_in_multipolygon called.");
#endif
for(i=1; i<mpolygon->ngeoms; i++)
if(point_in_polygon((LWPOLY *)mpolygon->geoms[i],
point)!=0) return 1;
return 0;
>From lwgeom_geos_c.c:
else if(type1 == MULTIPOLYGONTYPE && type2 == POINTTYPE)
POSTGIS_DEBUG(3, "Point in MultiPolygon test
requested...short-circuiting.");
mpoly = lwmpoly_deserialize(SERIALIZED_FORM(geom1));
point = lwpoint_deserialize(SERIALIZED_FORM(geom2));
if(point_in_multipolygon(mpoly, point) == 0)
PG_FREE_IF_COPY(geom1, 0);
PG_FREE_IF_COPY(geom2, 1);
lwgeom_release((LWGEOM *)mpoly);
lwgeom_release((LWGEOM *)point);
PG_RETURN_BOOL(FALSE);
else
PG_RETURN_BOOL(TRUE);
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
