[postgis-devel] Do you think we should put a note about 2D and 3D on each function?
Obe, Regina
robe.dnd at cityofboston.gov
Thu Sep 18 06:00:40 PDT 2008
I was thinking we should probably put a note on each function about what
is only supported for 2D and what works for 3D.
It would be nice to have a standard tag for this so we can tease it out
in an XSLT call into an index later on.
E.g. ST_Collect works for both 2D and 3D. ST_Union does some Z-index
averaging but not true 3d.
ST_Makeline works for 2D and 3D etc.
ST_AsText always returns a 2d rep where as ST_AsEWKT returns a 2d/3d
rep.
What are your thoughts on that? Seems like more people seem to be
trying to use the 3D support these days.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
