[postgis-devel] Invalid output from ST_BuildArea()
Kevin Neufeld
kneufeld at refractions.net
Thu Sep 18 08:31:31 PDT 2008
Well now that is interesting. That's what they say, eh? Never assume.
I think the check is a good one to make. I concur, loosen the checks
to 2D for now (at least until the geos issue gets resolved).
What about raising a notice, warning the user that they may want to snap
the endpoints of the ring before moving on?
Cheers,
Kevin
Mark Cave-Ayland wrote:
> Ah. It's a polygon with a ring where the first point != last point. So
> in other words, it seems that the ST_BuildArea()/BuildArea() functions
> are capable of producing invalid geometries :(
> Given that it appears to be the Z coordinate which is incorrect, I'm
> wondering if this is related to the "what does GEOS with the Z
> coordinate?" discussion currently happening on the GEOS list. Maybe the
> conversion checks from LWGEOM to WKT/WKB need to be loosened so that
> they only make use of 2 dimensions?
> Thoughts?
> Mark.
