[postgis-devel] Do you think we should put a note about 2D and3D on each function?
Obe, Regina
robe.dnd at cityofboston.gov
Fri Sep 19 05:46:39 PDT 2008
Is there an easy way to define a new tag or something for this. I was
thinking if we had a separate tag for it, it would be easier to pull out
those functions that have that tag later.
I guess we have similar issues with MM. Anyrate we can still do it if
we stick to the same terminology, but I figured it would be less prone
to error if we had a tag.
I am feeling a bit more confident about my XSLT abilities now that I
have a couple of unrelated projects that involved me having to write xsl
files to transform the data into another format. I was hoping to tackle
generating the function alter comments statements in the next week or so
trying to stick with just using a custom .xsl file for minimum increase
in dependencies.
Which brings me to the topic of if we create a custom xsl file for this,
where should we put this in the source tree or is this direction
completely wrong?
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: Thursday, September 18, 2008 11:19 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Do you think we should put a note about 2D
I think it's a good idea as well. 3D is definitely becoming more
popular.
-- Kevin
Mark Cave-Ayland wrote:
> Obe, Regina wrote:
>> What are your thoughts on that? Seems like more people seem to be
>> trying to use the 3D support these days.
> Ooooh. Yes please :)
> ATB,
> Mark.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
