[postgis-devel] SQL comment generation
Obe, Regina
robe.dnd at cityofboston.gov
Mon Sep 22 10:45:29 PDT 2008
That's what I was thinking the packaging would pre-build and it would be another
sql file similar to spatial_ref_sys.sql. Alternatively for release I guess we could manually build and put in the right location in svn. Would be redundant but oh well.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Chris Hodgson
Sent: Mon 9/22/2008 12:31 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] SQL comment generation
Or can we have the package-building process pre-build the documentation
and include it and the comments in the source tarball? I guess that
doesn't work for SVN checkouts... but for releases it seems like it
could be nice.
Chris
Kevin Neufeld wrote:
> Great work on this Regina. It looks good.
> Were you thinking this sql would be another file a user would load
> into a postgis database in addition to lwpostgis.sql and
> spatial_ref_sys.sql, or that we would concatenate it to
> lwpostgis.sql. I would love to see it in lwpostgis.sql, but that
> would mean folks would now have to build the documentation to get a
> spatially enabled database, whereas before they needn't bother. Hmmmmm.
> I wonder if we can do both. Have the makefile build the docs and
> concatenate the comments during the main build process if xsltproc is
> installed, otherwise, the docs don't build and lwpostgis.sql remains
> as is. No harm done.
> -- Kevin
> Obe, Regina wrote:
>> Mark,
>> I created a new xsl folder and committed the postgis_comments.sql.xsl I
>> created to that.
>> I also made some enhancements to it to include the arg names in the
>> comments. Sample generated sql file is attached and seems to work just
>> fine with xsltproc.
>> To test I ran the command
>> xsltproc -o postgis_comments.sql xsl/postgis_comments.sql.xsl
>> reference_new.xml
>> Though I guess that is not exactly the best place to put it.
>> In the process I discovered there is really no
>> ST_BdPolyFromText(text), ST_BdMPolyFromText(text)
>> or
>> ST_WktToSQL(text,srid)
>> even in the 1.4
>> These seem counter-intuitive to me since we have such constructs for
>> ST_GeomFromText, ST_GeometryFromText.
>> Anyrate if this all looks okay to you, can you integrate in the build
>> and figure out where the postgis_comments.sql should go.
>> As I mentioned I was eventually planning to create similar xsl files
>> that will comb out aggregate, mm and 3d compatible functions and
>> generate an additional toc doc .xml file from those that will then be
>> processed by our docbook generation step and simply provide an index
>> listing of said functions.
>> Can I chain these together like that? - xsl to generate docbox xml, then
>> docbook to build document?
>> Thanks,
>> Regina
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
>> This body part will be downloaded on demand.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080922/446e0d6d/attachment.html>
