[postgis-devel] Minimum number of points in a POLYGON ring?
David Fuhry
dfuhry at acm.org
Mon Sep 22 12:42:40 PDT 2008
Martin Davis wrote:
>> Having slept on it, my thinking is now along the lines of what I
>> suggested in my response to David's email - enforce the checks by
>> default, but provide a stored procedure to allow the checks to be
>> disabled for the duration of the session. Then people who want to use
>> PostGIS to process invalid geometries can explicitly invoke this
>> behaviour and so be aware of the consequences of doing so.
> Might this complicate debugging and error reporting? There would now
> be two different modes of operation, so some bugs and errors would
> require specifiying which mode is being used, and require the coder to
> ensure they tested under that mode. Not to mention two different
> pathways through the code...
As I understand it, Mark is proposing that the stored procedure would
only affect the behavior of the parser, nothing else.
Which I think is the correct approach.
-Dave
