[postgis-devel] Issue 54 in postgis: segfault with st_numgeometries when --enable-debug
codesite-noreply at google.com codesite-noreply at google.com
Mon Sep 22 16:46:49 PDT 2008
Issue 54: segfault with st_numgeometries when --enable-debug
http://code.google.com/p/postgis/issues/detail?id=54
New issue report by pwramsey3:
What steps will reproduce the problem?
1. compile postgis with --enable-debug
2. run select st_numgeometries(the_geom) on thetable limit 1
where the_geom is a multi* geometry column
Issue attributes:
	Status: Accepted
	Owner: pwramsey3
	Labels: Type-Defect Priority-High
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
