[postgis-devel] Issue 54 in postgis: segfault with st_numgeometries when --enable-debug
codesite-noreply at google.com
Tue Sep 23 06:02:58 PDT 2008
Issue 54: segfault with st_numgeometries when --enable-debug
http://code.google.com/p/postgis/issues/detail?id=54
Comment #2 by mark.cav... at siriusit.co.uk:
Gah. After a couple of hours of debugging, I can see what's happening - the
new
functions in SVN that perform the switch between malloc/palloc etc. assume
that you
can perform a variadic passthrough which isn't possible.
This is my fault - it'll take a little while, but I'll go fix it up so you
guys can
carry on debugging without crashing PostGIS.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
