[postgis-devel] autobuild cleanup - version revisited
Paul Ramsey
pramsey at cleverelephant.ca
Tue Sep 23 10:36:25 PDT 2008
OK, wrong again, mapserver on trunk is currently 5.3-dev, so there you
go. I know nothing.
P.
On Tue, Sep 23, 2008 at 10:34 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I really can't recall. I think I might have just been aping mapserver,
> which simply increments its versions in trunk when releases are
> tagged, so that mapserver 5.4 already "exists", though only as trunk.
> P.
> On Tue, Sep 23, 2008 at 6:49 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>> Paul,
>> Nudge Nudge - you have any opinion on this or do we have your blessing
>> to put the SVN back in the version numbers of 1.3.4 and 1.4.
>> Will the sky fall? Do we just need to change POSTGIS_MICRO_VERSION or
>> are there other changes to prevent things from breaking?
>> Thanks,
>> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Obe,
>> Regina
>> Sent: Monday, September 15, 2008 6:57 AM
>> To: PostGIS Development Discussion
>> Subject: RE: [postgis-devel] autobuild cleanup
>> Mark,
>> Sorry for the long-windedness (I was hoping to rank higher on dramatic
>> effect :).
>> Is it just the Version.config that controls that and would we put SVN as
>> part of the
>> POSTGIS_MICRO_VERSION. Although I vote to wait for Paul's opinion since
>> I assume he had some reason for doing that and perhaps have him do it.
>> Guess he doesn't get up until later in the day.
>> Thanks,
>> Regina
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
>> Cave-Ayland
>> Sent: Monday, September 15, 2008 5:46 AM
>> Subject: Re: [postgis-devel] autobuild cleanup
>> Obe, Regina wrote:
>>> Me too. Very important. While I think we should encourage users
>>> (somewhat) to test out and use 1.3.4 before released, I think its
>>> important they understand it is a moving (but somewhat stable target).
>>> I think we should put the SVN back in the version 1.3.4 until actually
>>> released. It was annoying me a bit that I don't see it in my
>>> postgis_full_version() output and was worried what if I forget to
>>> upgrade to the new one (or compile against my old source) when it is
>>> released, how would I be able to tell the difference?
>>> Thanks,
>>> Regina
>> I think that was exactly the point I was trying to make (but in a less
>> long-winded fashion!). Does anyone still have any objections to adding
>> the SVN suffix back into the SVN branches? If not, Regina, would you
>> like to add them back in?
>> ATB,
>> Mark.
>> Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
