[postgis-devel] autobuild cleanup - version revisited
Paul Ramsey
pramsey at cleverelephant.ca
Tue Sep 23 10:49:56 PDT 2008
Let's get fancy and do $Id substitution :)
1.4.svn-r21943
On Tue, Sep 23, 2008 at 10:44 AM, Chris Hodgson
<chodgson at refractions.net> wrote:
> That doesn't solve the problem of being able to tell the difference between
> installs of 1.4.0 from svn and of the 1.4.0 release version, which I think
> is the major complaint we have about not having the svn or -dev suffix. I do
> like the suffix approach as opposed to re-using the micro version... since
> it's nice to be able to tell the difference between micro versions that were
> taken from svn, too.
> Chris
> Kevin Neufeld wrote:
>> Then, what if the 1.3 branch is tagged as 1.3.SVN and trunk is left as
>> 1.4.0
>> Paul Ramsey wrote:
>>> I really can't recall. I think I might have just been aping mapserver,
>>> which simply increments its versions in trunk when releases are
>>> tagged, so that mapserver 5.4 already "exists", though only as trunk.
>>> P.
>>> On Tue, Sep 23, 2008 at 6:49 AM, Obe, Regina <robe.dnd at cityofboston.gov>
>>> wrote:
>>>> Paul,
>>>> Nudge Nudge - you have any opinion on this or do we have your blessing
>>>> to put the SVN back in the version numbers of 1.3.4 and 1.4.
>>>> Will the sky fall? Do we just need to change POSTGIS_MICRO_VERSION or
>>>> are there other changes to prevent things from breaking?
>>>> Thanks,
>>>> Regina
>>>> -----Original Message-----
>>>> From: postgis-devel-bounces at postgis.refractions.net
>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Obe,
>>>> Regina
>>>> Sent: Monday, September 15, 2008 6:57 AM
>>>> To: PostGIS Development Discussion
>>>> Subject: RE: [postgis-devel] autobuild cleanup
>>>> Mark,
>>>> Sorry for the long-windedness (I was hoping to rank higher on dramatic
>>>> effect :).
>>>> Is it just the Version.config that controls that and would we put SVN as
>>>> part of the
>>>> POSTGIS_MICRO_VERSION. Although I vote to wait for Paul's opinion since
>>>> I assume he had some reason for doing that and perhaps have him do it.
>>>> Guess he doesn't get up until later in the day.
>>>> Thanks,
>>>> Regina
>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
>>>> Cave-Ayland
>>>> Sent: Monday, September 15, 2008 5:46 AM
>>>> Subject: Re: [postgis-devel] autobuild cleanup
>>>> Obe, Regina wrote:
>>>>> Me too. Very important. While I think we should encourage users
>>>>> (somewhat) to test out and use 1.3.4 before released, I think its
>>>>> important they understand it is a moving (but somewhat stable target).
>>>>> I think we should put the SVN back in the version 1.3.4 until actually
>>>>> released. It was annoying me a bit that I don't see it in my
>>>>> postgis_full_version() output and was worried what if I forget to
>>>>> upgrade to the new one (or compile against my old source) when it is
>>>>> released, how would I be able to tell the difference?
>>>>> Thanks,
>>>>> Regina
>>>> I think that was exactly the point I was trying to make (but in a less
>>>> long-winded fashion!). Does anyone still have any objections to adding
>>>> the SVN suffix back into the SVN branches? If not, Regina, would you
>>>> like to add them back in?
>>>> ATB,
>>>> Mark.
>>>> Mark Cave-Ayland
>>>> Sirius Corporation - The Open Source Experts
>>>> http://www.siriusit.co.uk
>>>> T: +44 870 608 0063
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>> The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended
>>>> solely for the addressee. If you received this in error, please
>>>> contact the sender and delete the material from any computer.
