[postgis-devel] autobuild cleanup - version revisited
Obe, Regina
robe.dnd at cityofboston.gov
Tue Sep 23 10:47:07 PDT 2008
I suppose we can't have the 1.3.4 in there so its
1.3.4SVN
It is a bit of a petty point I guess - but I don't want to see someone's version number yeh down the road and wondering
is that
1.3.2SVN or 1.3.3SVN or whatever.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Tue 9/23/2008 1:43 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] autobuild cleanup - version revisited
Sher.
On Tue, Sep 23, 2008 at 10:39 AM, Kevin Neufeld
<kneufeld at refractions.net> wrote:
> So, branch is 1.3.SVN and trunk is 1.4.SVN?
> -- Kevin
> Paul Ramsey wrote:
>> OK, wrong again, mapserver on trunk is currently 5.3-dev, so there you
>> go. I know nothing.
>> P.
>> On Tue, Sep 23, 2008 at 10:34 AM, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> I really can't recall. I think I might have just been aping mapserver,
>>> which simply increments its versions in trunk when releases are
>>> tagged, so that mapserver 5.4 already "exists", though only as trunk.
>>> P.
>>> On Tue, Sep 23, 2008 at 6:49 AM, Obe, Regina <robe.dnd at cityofboston.gov>
>>> wrote:
>>>> Paul,
>>>> Nudge Nudge - you have any opinion on this or do we have your blessing
>>>> to put the SVN back in the version numbers of 1.3.4 and 1.4.
>>>> Will the sky fall? Do we just need to change POSTGIS_MICRO_VERSION or
>>>> are there other changes to prevent things from breaking?
>>>> Thanks,
>>>> Regina
>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Obe,
>>>> Regina
>>>> Sent: Monday, September 15, 2008 6:57 AM
>>>> Subject: RE: [postgis-devel] autobuild cleanup
>>>> Mark,
>>>> Sorry for the long-windedness (I was hoping to rank higher on dramatic
>>>> effect :).
>>>> Is it just the Version.config that controls that and would we put SVN as
>>>> part of the
>>>> POSTGIS_MICRO_VERSION. Although I vote to wait for Paul's opinion since
>>>> I assume he had some reason for doing that and perhaps have him do it.
>>>> Guess he doesn't get up until later in the day.
>>>> Thanks,
>>>> Regina
>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
>>>> Cave-Ayland
>>>> Sent: Monday, September 15, 2008 5:46 AM
>>>> Obe, Regina wrote:
>>>>> Me too. Very important. While I think we should encourage users
>>>>> (somewhat) to test out and use 1.3.4 before released, I think its
>>>>> important they understand it is a moving (but somewhat stable target).
>>>>> I think we should put the SVN back in the version 1.3.4 until actually
>>>>> released. It was annoying me a bit that I don't see it in my
>>>>> postgis_full_version() output and was worried what if I forget to
>>>>> upgrade to the new one (or compile against my old source) when it is
>>>>> released, how would I be able to tell the difference?
>>>>> Thanks,
>>>>> Regina
>>>> I think that was exactly the point I was trying to make (but in a less
>>>> long-winded fashion!). Does anyone still have any objections to adding
>>>> the SVN suffix back into the SVN branches? If not, Regina, would you
>>>> like to add them back in?
>>>> ATB,
>>>> Mark.
>>>> Mark Cave-Ayland
>>>> Sirius Corporation - The Open Source Experts
>>>> http://www.siriusit.co.uk
>>>> T: +44 870 608 0063
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>> The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended
>>>> solely for the addressee. If you received this in error, please
>>>> contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080923/b7e50573/attachment.html>
