[postgis-devel] Issue 54 in postgis: segfault with st_numgeometries when --enable-debug
codesite-noreply at google.com
Tue Sep 23 13:39:52 PDT 2008
Issue 54: segfault with st_numgeometries when --enable-debug
http://code.google.com/p/postgis/issues/detail?id=54
Comment #6 by pwramsey3:
This error is on Centos 5.1. I haven't checked to see if it also happens in
OS/X.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
